Sep 8, 2011 5:51 PM UTC
INSERT/G5 P10000
Dear Pro/mfg Gurus,
In the customize tab I am inserting manually the following command.
INSERT/G5 P10000
The selected option in cl command is Current.
In the customize tab the additional command appears as following:
    Sep 8, 2011 6:37 PM UTC
    Thank you guys for your help,
    The format that worked is, INSERT/G5 P1000$
    ( $ at the end )
    Thank you all.
    Georgios L.
