Interaction with Pro/ENGINEER embedded browser
Has anyone had any success in automating/scripting Pro/ENGINEER such
that the program interacts with the embedded browser? Both logging in
and using the embedded browser do not get captured by the trail file.
This is being cross-posted as it involves both Pro/ENGINEER and
Windchill. Any help or suggestions would be appreciated. Thanks.
John M.
    John,
    Look into Pro/Web.Link (javascript) or Pro/J-Link (java) for programming
    applications that interact with Pro/Engineer via the embedded browser.
    You can find the help files for these in the Pro/E loadpoint/weblink or
    loadpoint/jlink respectively. To get these interfaces (and the
    mentioned folders) you do have to check the appropriate options in the
    installer but there is no extra license required.
    Best wishes,
    Kevin
    Kevin Schoonover
    PTC Channel Technical Manager
    Western North America
