Intersect in WF?
Hi, All:
For the first time ever, I need to create a curve of the intersection of two
surfaces, and naturally, I can't get it to work. The menu mapper says to use
Edit-->Intersect, but when I select the two surfaces and pull down the Edit
menu, Intersect is still grayed out. What am I missing?
    unknown11-VisitorAuthor
    Works for me.
    Are you perhaps selecting features instead of surfaces?
    Rui
    "Carol Fly" <flycg@alexmail.com> wrote in message news:43634@model...
    Hi, All:
    For the first time ever, I need to create a curve of the intersection of two surfaces, and naturally, I can't get it to work. The menu mapper says to use Edit-->Intersect, but when I select the two surfaces and pull down the Edit menu, Intersect is still grayed out. What am I missing?
