Mar 25, 2015 11:09 AM UTC
Is Creo Elements/Pro 5.0 avaible in student version?
I have a problem, because my thesis supervisor uses Creo Elements/Pro 5.0 and I need to work on some files from his computer.
As I see, there is only Creo Parametric 3.0/2.0 or 1.0 avaible for student to download, and they are not compatible.. Where can I get Creo Elements/Pro 5.0 from?
And he has commercial version. Is there any way to work on his files using student version?
    Mar 25, 2015 12:37 PM UTC
    Oskar,
    Commercial and Student versions produce incompatible data files. This is the base of your problem !
    Martin Hanak
    owysocki1-VisitorAuthor
    Mar 25, 2015 1:15 PM UTC
    Thank you Martin for your reply.
    So I guess I'll have to build this models by myself from the begining...
    Anyway, is anywhere the Creo Elements/Pro 5.0 student version available to download?
    Mar 25, 2015 1:34 PM UTC
    Oskar,
    if you do not need feature based model, then you can ask your supervisor to export models into STEP or IGES format and import these files on your workstation.
    Ask - question "How to downalod Creo Elements/Pro 5.0 student version ".
    Martin Hanak
