Sep 16, 2010 4:49 PM UTC
is it true?
ProCadsters,
Is it true the PTC left out the ability to delete a row or column in a
table in WF4?
The standard old path appears to be greyed out, nor there is there a
delete selection in the context menu.
Am I just looking in the wrong place?
Words of wisdom or a work around would be graciously accepted.
Glen R Wisham
MOEC EW Mechanical Engineering
Space and Airborne Systems
Raytheon Company
805.879.3359 (office)
805.879.3017 (fax)
561.3359 (tie line)
6380 Hollister Avenue
Goleta CA 93117-3114 USA
    Sep 16, 2010 5:25 PM UTC
    ProCadsters,
    I now have a solution and believe that I had a 'slightly corrupt' table or
    a very localized repeat region.
    The table verified as having no repeat regions, however after selecting
    the entire table and forcing a remove repeat region anyway, I was able to
    delete individual rows and columns again.
    Thank you all for your excellent suggestions and help.
    Glen R Wisham
    Raytheon Company
    805.879.3017 (fax)
    561.3359 (tie line)
