Apr 6, 2012 7:10 AM UTC
Is there a way to show thread on model surfaces in case I use shaded with edges model display?
Hello, everyone.
I didn't have this kind of problem in other CAD systems like SolidWorks or Inventor.
But now I have to switch from shaded with edges model display to wireframe or hidden line model display every time I need to see thread on model surfaces.
Best regards, Vladimir.
    Apr 6, 2012 5:09 PM UTC
    You're saying that you can see threads in Wireframe mode, but not in Shaded mode, correct? If you modeled true threads then you can see them in any mode, but if you created Cosmetic threads, which is a cylindrical surface that will show as hidden lines in a drawing to reprsent threads, or a Hole feature then threads will not show in Shaded mode.
    If you want to see threads in Shaded mode, you'll have to model threads or use a special color or "texture" to represent threads.
    Apr 9, 2012 4:33 AM UTC
    Thank you very much for your answer, Kevin.
    I like the idea to use special colour for surfaces with threads.
    Apr 9, 2012 1:11 PM UTC
    My pleasure.
    Out of curiosity, are your threads Cosmetic threads?
    Apr 17, 2012 7:36 PM UTC
    Oh how I miss SW cosmetic threads....
    Apr 18, 2012 12:51 PM UTC
    So do I ...
    Apr 18, 2012 1:11 PM UTC
    Take a vote on this idea?
    http://communities.ptc.com/ideas/1068
