Is WF4 compatible with Pro/Intralink3.4 ?
until now I thought WF4 was not compatible with Pro/Intralink3.4. But recently, I was said it is. Do you know if this is true, and which version (datacode) of WF4, and Intralink3.4 are needed ?
    With a brief search on the PTC website I found a link to this pdf file that I believe answers your question.
    http://www.ptc.com/WCMS/files/24313/en/SWCompatibility34061809.pdf
    It basically says that if you are running Intralink 3.4 M06X then you need WF 4 M030+ or if you are running Intralink 3.4 M070 then you need WF 4 M080+
    Hope this helps!
    -Greg
    Hope this helps!
    -Greg
    Canopys1-VisitorAuthor
    It does. Thanks.
