ISO HOLE ERROR
Dear Folks,
Facing an issue when the iso hole created in creo/elements pro 5.0
I have attached screen shot please view it and review it.
why i can't create those?
Thanks & Regards
Viswanathan.K
    visuAnswer
    Dea Folks
    The ISO HOLE ERROR because of part accuracy value.
    Later i increased the part accuracy value then it is created succesfully.
    Thanks & regards
    Viswanathan.k
    Check in the 'Shape' tab and make sure that the values for the tapping drill and the thread make sense.
    visu1-VisitorAuthorAnswer
    Dea Folks
    Thanks & regards
    Viswanathan.k
    Viswanathan,
    I'm going through the same annoying problem. Could you describe the steps you took to increase the part accuracy value, as I am new to Creo? Thanks in advance.
    Creo uses a relative accuracy setting in the model properties (file>prepare>model properties). You can try setting this to a more refined value. Default is .0012. There is also an "absolute" accuracy capability but you have to enable this 1st in config.pro: enable_absolute_accuracy no*/yes and you might also look at all the "accuracy" settings you can specify in config.pro. Personally, I also set default_abs_accuracy to .00005.
    I really REALLY REALLY find this whole accuracy thing annoying in Creo. I understand why it is there, but internal management of this should be transparent to the user. This would be MUCH better handled in a failure handling mechanism where accuracy would be set base don the users! needs, not the software. Warning are fine, but feature failure due to accuracy setting? Not acceptable in this day and age.
