Dec 17, 2010 4:20 PM UTC
Keep propertie of general view
Helllo,
How could I keep the properties of my general view when I'm creating a projection view?
Each time I have to go to properties and change my setup.
Simon Gauthier
Bain Ultra
St-Nicholas, PQ
    Dec 21, 2010 9:57 PM UTC
    Can you be a little more specific? Usually when you create a projection view, the projection takes on all of the properties of the parent view. Anything done to the parent will be reflected on the projection.
    Dec 22, 2010 10:34 AM UTC
    If you're referring to things such as the display style, they don't carry over in WF4 (unless we're missing a config option).
    I can have a view set up with No Hidden, Tangent None, and when I create a projection view from it, it takes on Follow Environment instead.
    I have to select each new view (or all of them together - a small time saver) and change the display settings every time.
    Dec 22, 2010 12:53 PM UTC
    Try setting the model_display_for_new_views options in the drawing.dtl file (drawing options).
