May 24, 2013 12:19 PM UTC
link between pro-program and mapkey
hi everyone,
Is it possible to operate a mapkey automatically or by a Pro-program??
e.g I have a parameter called ABC and a mapkey called XYZ.
if ABC = Yes than the mapkey XYZ will run otherwise not.
please help me if anyone knows this.....
    TomU
    May 24, 2013 12:44 PM UTC
    No, you cannot. Mapkeys are called from the environment. The model responds to the environment.
    There may be a way to write a custom J-Link program and embed it into the model. This could then execute some command (or possibly even a mapkey) when a certain value is entered in a parameter.
    May 25, 2013 5:27 AM UTC
    thank you tom,
    but can u please give me a example of that if possible.????????
    May 25, 2013 6:52 PM UTC
    Hey ptc-4958059,
    ProPROGRAM is a configuration tool i.e. it is applied on a "generic" type part to create its configurations. So there is a need to create fully sustainable "generic" part first.
    Can you explain what kind of mapkey you want to link to PROGRAM condition, probably based on the above you still can perform your tasks with ProPROGRAM classical usage without a mapkey ?
