Jun 3, 2015 2:49 PM UTC
Locked dimensions
I have a project that all of a sudden the relations programs will not change dimensions in the project.  It acts like it is locked and will not let them be modified by the relations.  I can go into sketcher and manually change the dimensions.
    mganzerAnswer
    2-Explorer
    Jun 3, 2015 4:45 PM UTC
    Did you accidentally add any relations in the sketcher? Those would stop modification and would not show up as relations outside the sketcher.
    mganzer2-ExplorerAnswer
    2-Explorer
    jhailey1-VisitorAuthor
    Jun 3, 2015 4:53 PM UTC
    No, I just found the problem and had an extra else stmt in my if-else stmts.  It was not allowing the code to run that I needed to run.
    Thanx.
    Dale_Rosema
    Jun 3, 2015 5:56 PM UTC
    Hate it when the code does what you tell (or don't tell) it to do..
