Loft Icon??
Where do I find the loft command? Wish there is a command finder like they have in NX.
Thanks for any help!!
    Depending on what you are trying to do the feature you may want is the BLEND feature, there is no LOFT feature.
    MukaSingh1-VisitorAuthor
    I'm trying to extrude from a circle on one end and the other end is rectangular shaped. In Solidworks or NX you can do a loft using two separate sketches to accomplish this.
    You can do that with a BLEND. You need to split the circle into four segments with the sketcher divide command so it can be blended with the square.
