Make 3D model look more like SoldWorks Model
Hi is there a way to make 3D shaded models look more like SolidWorks models? Example:
    Please reply on which options to change. Thks, E-
    LeeCasey1-VisitorAuthor
    Sorry I should have been more specific. I mean the thick lined edges of the model.
    View, Display Settings, Model Display... Shade Tab, select "With Edges" box. I don't know if you can change the color of the edge lines, it seems to take the color of the object itself. Play around with that and see if it works out for you. Chris
