Manifold Solid Brep
I get this when I convert data from STP file, is this just a file that is created to represent a solid component that has no file number associated to it?
    I have similar results when receiving a STEP file from a UGS NX data set. Even worse than having no part number associativity, if there are twelve instances of a common bolt in the assembly, it generates twelve separate "manifold_solid_brep_XXXX.prt files. Any insight as how to prevent this during STEP file creation would be appreciated.
    I think that what Pro-e does, is that it cannot recognize ref. sets in a file, so if that file has 12 solids in it and they are all called out by different ref sets Pro-e will just create them as manifold solid breps. I do not know any way around this or how to fix it.
    We get a similar problem to Mark's, with stepped files of motors from Inventor... every cooling fin on the motor comes in as a separate "brep" file.
