Mar 12, 2012 1:59 AM UTC
Map of Commands, Wildfire 4 to Creo Parametric
I apologize if this has already been asked and answered in a previous post but I did search the forums and was unable to locate this information.
Basically I'm looking for an aide or map where I can select a command or menu item from Wildfire 4 and it will show where it's at in Creo Parametric.
Thanks for the help........
Stacy
    Mar 12, 2012 8:41 AM UTC
    Stacy,
    in Creo Parametric 1.0, you can use Command Search box to find requested command. See the following picture.
    Martin Hanak
    Stacy,
    Martin Hanak
