Mapkey Experts
I am trying to create a map key that involves the "file open" dialog box
in the middle of a mapkey. The problem is that Pro/E records the name
of the file selected and just opens the same file everytime I run the
mapkey. If I delete the file name from the mapkey then Pro/E stops a
that point so I can select a different file but the mapkey does not
continue after that like it should.
Anyone have any suggestions on how to handle this?
Thanks!
    gkemner1-VisitorAuthor
    Thanks to everyone that has suggested using the "PAUSE" option in the
    mapkey. I tried that but that still didn't get it either. When you run
    the mapkey and click on resume it changes the window focus and that
    messes up the rest of the mapkey.
    Specifically I want the mapkey to do the following in an assembly:
    * Insert -> Component -> Assemble ( I can do this just fine)
    * Allow me to pick the component to assemble (This is where it
    breaks down)
    * Click on the separate component window that pops up and move it
    to a different place on the screen (I can do this also, but not all of
    it together in one mapkey)
    If I use the pause option then when I hit resume the separate component
    window pops behind the main window and the mapkey fails to move it as
    desire.
    Any other thoughts? Thanks!
