2-Explorer
mapkey that uses actual keystrokes
Does anyone know if it is possible to record or write by hand a mapkey that uses your actual keystrokes, as i have only seen mapkeys that record the menu options that you select.
    Dale_Rosema
    I have made mapkeys with a combination of keystrokes with a couple of mouse clicks to save the current drawing file as a dwg.
    After naming and describing the mapkey, I turned on Record.
    Alt-F, Z A (file saveas Creo 2.0)
    I had to mouse click to change from .drw to .dwg.
    I mouse clicked to get on the name bar.
    Home key (to move the curser in front of the existing name).
    v ( to add the letter v in front of the name for the in house viewer program).
    I mouse clicked enter (though I may have been able to enter from the keyboard).
    I stop recording.
    Saved
    Clear the file that had been made while creating the mapkey
    Tested and it worked.
    I hope this helps.
    Dale
