Apr 17, 2014 5:41 PM UTC
Mapkey using right button menu
Hi all,
I'm not able to create a mapkey where I have to activate a command present in a right button menu, after selection a model.
Eg.
mapkey _test ~ Timer `UI Desktop` `UI Desktop` `popupMenuRMBTimerCB`;\
mapkey(continued) ~ Close `rmb_popup` `PopupMenu`;~ Command `user_popup_item_cmd`;
That command is not present in any other place on the ribbon.
Any possible solution?
Apr 23, 2014 12:49 PM UTC
I think you have to create a button for that command and then record a mapkey pressing that button.
File->Options->Customize the ribbon->Choose from Toolkit commands-> Choose your command
When recording the mapkey first select the tab where the button is and then press the button.
Jose
