MapKeys: Pro/E WF2.0
Can I create a mapkey, which consists of more than one commands
(including keyboard/mouse inputs)? Is it possible ??
Please reply ASAP.
Thank You,
Anup More
    18-Opal
    Yes, it is quite possible. That is part of the power of mapkeys. One of the things to watch out for when creating mapkeys is that you start commands from the menu bar, not icons that can move around. This will make the mapkey more robust.
    I think it's available in WF 2, but make sure the config.pro option
    cmdmgr_trail_output is set to yes (default in WF4)
    This will record all mapkeys and trail files as 'API' commands
    independent of menus / mouse clicks...
    Christopher Gosnell
    TRIGON INC.
    FPD Company
    124 Hidden Valley Road
    McMurray, PA 15317
    PH: 724.941.5540
    FX: 724.941.8322
    www.fpdinc.com
    anup.more1-VisitorAuthor
    Are there any options to make a mapkey consisting of more than one
    comand?? How can I add mouse or keyboard inputs in a mapkey??
    Plz reply ASAP.
    Thanking You
    Anup More
