Dec 1, 2015 4:49 PM UTC
mass does not update
amount=pro_mp_mass relation does not update.
Mass properties report lists 17.34 lbs, amount param shows 34 lbs
material =  steel
    Dec 1, 2015 5:01 PM UTC
    to re-compute mass properties, click File > Prepare > Model Properties > change (in Mass Properties row) > Calculate (in Mass Properties dialog box).
    Copied from Re: Center of Gravity is not changing
    MH
    Dec 1, 2015 4:53 PM UTC
    You need to calculate the MP from the File-Prepare material menu, then regen to update the parameter.
    This was discussed last week.
    MH
    Mahesh_Sharma
    22-Sapphire I
    Dec 8, 2015 5:34 PM UTC
    Hi Frank,
    I hope replies in this post help you. Kindly mark the appropriate reply as correct answer for the post.
    Dec 8, 2015 5:39 PM UTC
    Yes the intructions work. the bad news is that if you have parts in a family table you have to open and repeat this for each one!!!!!
    Dec 8, 2015 8:05 PM UTC
    No you don't. Open the generic and add a pro_mp_mass column (or your parameter that is set to pro_mp_mass) to the FT, then verify the FT and all of the weights are updated. Checkout the generic and all instances and check them back in.
