Mass properties in notes
Greetings,
Does anyone know how to place mass property values into a note? Specifically I'm looking to use Ixx, Iyy and Izz at COG with respect to coordinate system. Putting in &pro_mp_Ixx inserts the value with respect to the coordinate system. I need the value at COG with respect to coordinate system. Is there a suffix needed on the end of the inertia value designator like &pro_mp_Ixx:???
Any help would be greatly appreciated.
Bill Watkins
Sandia National Labs
Albuquerque, NM
505-845-9666
    The note creation is a3 step process.
    First in the part, you set mass property (ieABS = .0379)insert a mass property FEATURE and set it to become a footer.
    (Failing to make it a footer in the feature table will not include subsequent features.)
    Second you write a relation in the relations pulldown command.
    MASS=MASS:FID_MASS_PROP_1
    Lastly in the drawing thenote would read
    NOTE:
    1. MATERIAL MASS: &MASS lbs
    hope that helps.
    I have done this without the relation.
    I create an analysis feature called Mass_Analysis and place it in the footer. Then I will create a note that reads "Part Weight &mass:fid_mass_analysis[.2] LB" I use weight to not confuse the purchasing and marketing types, and the [.2] truncates the decimal places to 2. It defaults to 3. We are now looking at making this a part of our format and will be included automatically oon all drawings. The Analysis feature is a part of our start parts and assemblies.
    Brent
