Material Files - Share?
Does anyone havea basic set of material files they can share (preferrably with appearances defined) - WF3 or later.
Big thanks in advance,
Paul
    Check MCAD Central, I've downloaded this, but we don't do much FEA so I can't say as to the file's accuracy.
    http://www.mcadcentral.com/proe/files/gallery.asp
    I believe there's a zipped materials file in the Miscellaneous section.
    Hope this helps,
    Rodney (WF3 M140)
    This has come up twice in the past few months, once my me. I didn't
    respond because you asked specifically for WF3 versions.
    I received a large number of material files, based on the ones at MCAD
    Central, but they are all the old old format I have had no luck in
    converting them. WF3 will open them, but any edits result in an
    unsavable material file where the blank fields are tagged as 'invalid'.
    Blank fields should be acceptable, in fact they were fine until I
    changed something else.
    I gave up.
    Doug Schaefer
    Here as some that should be in WF3 format... I'm currently using them in
    WF4, but converted them back in WF2 or 3...
    Paul Korenkiewicz
    FEV , Inc.
    4554 Glenmeade
    Auburn Hills, MI, 48326-1766
    This would also be an excellent thing to post to the Files section of
    portal.ptcuser.org, if you're willing.
    Lyle Beidler
    MGS Inc
    178 Muddy Creek Church Rd
    Denver PA 17517
    717-336-7528
    Fax 717-336-0514
    <">mailto:-> -
    <">http://www.mgsincorporated.com>
    Good to know. I've only used them for mass calculations thus far when customers or our shipping dept. needed to know approximate assembly weights.
    Rodney
    In Reply to Doug Schaefer:
    I gave up.
    Doug Schaefer
    Senior Project Engineer, Mechanical
    www.design-central.com http://www.design-central.com
    Tel +1 614 890 0202
    Fax +1 614 890 5880
    Design Central designet
    6464 Presidential Gateway
    Columbus, Ohio 43231
    USA
    done... to the public areas/configurations under WF3 material files...
    Paul Korenkiewicz
    FEV , Inc.
    4554 Glenmeade
