2-Explorer
Mar 19, 2014 1:38 PM UTC
materials 2
Hi again,
Also, where is the Materials Folder? (and WHY is it so hard to add a new
material to it?)
-Nate
    Mar 19, 2014 2:51 PM UTC
    You can put your materials database anywhere you want. Use this config option:
    pro_material_dir P:\pro_lib\materials
    For us this is on a network drive that everyone looks at.
    Creo pays attention to sub directories inside of the material folder, so you can organize your material in sub folders.
    The question is do you just want density? Or do you need the complete material properties?
    If all your doing is getting weights, you can easily create multiple materials by just copying and editing the text files.
    For example we have a folder for density only materials. Here's one, just copy and edit the hi-lited lines and the name of the file.
    Acrylic_si.mtl
    ND_RelParSet_K01 = {
    Name = acrylic_si
    PARAMETERS =
    Name = PTC_MATERIAL_DESCRIPTION
    Type = String
    Default = 'acrylic_si - Density Only'
    Access = Full
    Name = TEMPERATURE
    Type = Real
    Default = 2.000E+01 C
    Access = Full
    Name = PTC_MASS_DENSITY
    Type = Real
    Default = 1.180000E-03 g / mm^3
    Access = Full
    Name = COMMON_NAME
    Type = String
    Default = 'ACRYLIC'
    Access = Full
    David Haigh
