Materials Library file
Any one know where I can find a good materials library file,
I need to set one up here.
Robert Parsons
Designer
Phone 336-547-5604
7300 Friendly Ave.
Greensboro, NC. 27409
This message (including any attachments) contains confidential
and/or proprietary information intended only for the addressee.
Any unauthorized disclosure, copying, distribution or reliance on
the contents of this information is strictly prohibited and may
constitute a violation of law. If you are not the intended
recipient, please notify the sender immediately by responding to
this e-mail, and delete the message from your system. If you
have any questions about this e-mail please notify the sender
immediately.
Ce message (ainsi que les 'eventuelles pi`eces jointes) est exclusivement
adress'e au destinataire et contient des informations confidentielles. La
copie, la communication ou la distribution du contenu de ce message sans
l'accord pr'ealable de l'exp'editeur sont strictement interdites et peuvent
constituer un d'elit. Si vous n'^etes pas le destinataire de ce message,
merci de le d'etruire et d'avertir l'exp'editeur. Si vous avez des
questions se rapportant `a ce courrier 'electronique, merci de bien vouloir
notifier l'exp'editeur imm'ediatement.
