Mar 5, 2007 3:01 PM UTC
Measure: Edge-to-Plane
Okay..... I just burned up half the A.M. trying to figure out how to measure in Wildfire. Completely frustrated, any suggestions? I simply would like to know the distance from one component to another. My old mapkey for measure edge to plane doesn't work in wildfire. Thanks for your responses.
    Mar 5, 2007 3:08 PM UTC
    Yes, it is very frustrating... Under the Definition tab, you check USE AS PLANE
    Mar 6, 2007 1:32 PM UTC
    Paul: thanks for the info. the next 'fun' thing is to measure an angle.
    Mar 7, 2007 11:00 AM UTC
    I had the same problems mate Fear not, they are making big changes to the measuring in WF4, so that you dont need 20 clicks just to measure a simple distance 😛
