Apr 30, 2015 10:32 PM UTC
Measure Tool
I am seeking assistance with the measure tool. After I click on an initial reference (which highlights in green) then click the second reference (which highlights in green and the original un-highlights itself) for the dimensinal information I need, the second reference replaces the original in the populated box and no dimensional information is given. Is this an issue with some kind of "snap" setting? I am using Creo 2.0.
Thanks for your assistance!
    Mahesh_Sharma
    22-Sapphire I
    Apr 30, 2015 10:40 PM UTC
    When using Measure tool use CTRL (Control Button) to select references, Select first Reference > CTRL > Select Second Reference.
    I hope this helps.
    Mahesh_Sharma
    22-Sapphire I
    I hope this helps.
    jjacobs1-VisitorAuthor
    May 4, 2015 12:10 PM UTC
    Thank you for your assistance!
