Mar 5, 2012 12:16 AM UTC
Measuring in PTC
I've used Autodesk for a year or so and they have this really handy tool to measure distances between models. I was wondering of PTC had a tool like this, and if so how to use it.
    Mar 6, 2012 2:05 AM UTC
    Hi
    The video you have seen is in Creo Parametric 1
    This is not an older version(This is the latest version)
    The User Interface(Ribbon) is different, but the options are same.
    You will find these options in Analysis(dropdown)>Measure
    For easy use you can add these tools in your toolbars
    Regards
    K.Mahanta
    Mar 5, 2012 9:12 AM UTC
    Hi
    Check the following link from Learning Exchange
    http://learningexchange.ptc.com/tutorial/455/measuring-models
    Regards
    K.Mahanta
    Mar 6, 2012 12:14 AM UTC
    I apologize for not specifying which program I am using. I'm using creo elements/pro 5.0
    It seems to be a much older version of the one displayed in the tutorial link you gave me, and it has a much different menu and from what I can see; No quick easy tools to measure.
    Hi
    Regards
    K.Mahanta
