Oct 14, 2015 4:27 PM UTC
Medium Fit for Thru Holes in UNC Hole Tables
WHY isn't it there?
WHERE do I send my hate mail?
WHAT are you going to do about it?
HOW about you add the 3 lines of code to fix this problem in the next version so companies don't have to spend millions to work around dumb artificial restrictions on customization?
WHEN is it going to happen?
WHO thinks PTC even reads these?
I'll hang-up and listen.
Oct 14, 2015 4:48 PM UTC
I agree, that the entire hole table should already be populated by PTC, out of the box, but...
Edit the hole table that is included with Creo to include the values you want.
Oct 14, 2015 4:51 PM UTC
I modify the OOTB hole files anyway because the PTC supplied tables use theoretical values and we use actual values for drill sizes.
Only has to be done once and moved to a new version with ease.
ryates1-VisitorAuthor
Oct 14, 2015 4:53 PM UTC
Unfortunately, there isn't even an OPTION to set up Medium Fit for clearance holes on inch based fasteners. Only for Metric. We've been using custom hole tables for many years.
