Minimize or shut off Mechanica UI
Does anyone recall the environmental variable or demo option that shuts off or minimizes the Mechanica UI ? I'm running mechevent files and do not want to see the UI.
Thanks in advance.
    Dear Joe,
    mstruct -g
    Used to work when I used Mechanica on Unix. I've never used it on Windows,
    so I don't know the appropriate command syntax.
    Rod Giles
    Elite Consulting Ltd.
    Mechanica Specialists since 1992
    Another option (depending on what Joe is trying to achieve) is to setup
    Batch Run jobs within the Analysis dialog box instead of running them
    interactive. This will cause just the msEngine to run which has no
    graphics. This frees up memory taken up by the heavy xtop and mstruct UI's.
    PS. Don't forget to turn off your anti-virus software while running
    analyses. Depending on your AV vendor this can have a signigficant impact
    on your analysis time.
    Gavin B. Rumble, PE
    Solid Engineering
    336-224-2312
