Sep 14, 2015 4:14 PM UTC
Model Tree display in the "Navigation Tabs"
User does not have the option to display the Model Tree in the "Navigation Tabs".   How do I get that option back?
    2-Explorer
    Sep 18, 2015 5:36 PM UTC
    Hello Greg,
    Usualy the model tree is displayed when a model is open.
    Then you can switch to Layer Tree instead and back to Model tree from the Show > Model Tree.
    Then one layer higher there are the tabs for Tree, Folder Browser and Favorites.
    And finally in the lower left corner you can switch Navigator on/off.
    Is any of the buttons inaccessible or did it disappear?
    Gunter
    Sep 24, 2015 9:12 PM UTC
    I would check these two things.
    1) in options>window settings> heading "model tree settings"
         is "display as separate window" checked or unchecked?
                   (should be unchecked)
    2) in the config.pro options     enable_tree_indep yes/no
              (should be no)
    if both of these are set correctly and you are still not seeing the tree, go to view>show>model tree
