Jul 19, 2016 3:29 AM UTC
Modifying hidden line
Hi, how to change hidden line colour for Pro Engineer Wildfire 5.0?
    Jul 19, 2016 10:09 AM UTC
    Hello, you need to click View, Display Settings, System Colors. You then select Hidden line & change the colour. If this is to be permanent you will need to save a new system colors file in your load point directory & point your config.pro file at it.
    Regards
    John
    Regards
    John
    Jul 19, 2016 10:12 AM UTC
    you can change your color scheme according to your needs.
    View > Display Settings > System Colors > Graphics tab > Hidden Line item
    MH
    mselamat1-VisitorAuthor
    Jul 20, 2016 1:11 AM UTC
    Hi John & Martin,
    Thank you. It simply works!
    Muzzammil
