Modifying Hole Callout
Hideho, How we modify the hole command (callout) to fit my company's
standard.
It's a pain to edit it and you lose to parametric qualities of the system.
Using WildFire 2.0
I'm glad your out there. There are only 2 of here that use Pro-E.
Which by the way I find a excellent program. I've used Catia, AutoCad and
Pro is the best!!!
Thanks.
    Mike,
    Here is the info from the Pro/E Help. Read through it and you should be
    able to fully customize your hole note.
    Nicolas Hostein
    Mechanical Engineer
    BioValve Technologies
