Dec 5, 2012 10:52 PM UTC
Moldflow & CREO2
We are trying to tie moldflow into Creo2 has anyone been able to configure the two.
Take care,
JEREMY HANDLER
Mechanical Engineer
1+760-591-7318
[Description: Grren] Consider the environment. Consider the impacts.
    Dec 5, 2012 11:03 PM UTC
    Hi Jeremy,
    As far as I know now they are not linked internally as in the past. You
    get Design Link which allows your Moldflow to directly read the ProE/Creo
    files but you do not fire up Moldflow from within Creo as it was a few
    releases back.
    It was explained to me that it is just too hard for AutoDesk to keep the
    links into ProE/Creo up to date. Not sure when this changed but certainly
    true for Moldflow 2013 the present release.
    *Brent Drysdale*
    *Senior Design Engineer*
    Tait Communications
