Jan 6, 2016 1:13 AM UTC
Movable text in a symbol?
Folks,
I'm trying to define a symbol with variable, MOVABLE text, without leaders. I created a note like so: \LOC\ and am able to change the value without a problem. However, the text is fixed in one place when I place the symbol. The text indicates the position of a detail in a grid like A-12, Q49, T99, etc. but it's position needs to be tweaked for maximum clarity.
My current symbol is only a circle with filled hatching. I have to create a text-only separate note that has no associativity; moving one will not move the other.
Any ideas? I'm using Creo 2, M100.
Ray Aviles
    dschenkenAnswer
    2-Explorer
    Jan 6, 2016 3:41 AM UTC
    Symbols don't support movable internal pieces. You can create a note and select 'offset' as the placement, then pick a symbol to be the anchor and then pick another location for placement. When the symbol is moved the note will follow along. I never remember whether it's the middle or the left button to pick the location; just randomly click until it works. I think it is opposite for placing symbols with 'offset'.
    dschenken2-ExplorerAnswer
    2-Explorer
    raviles1-VisitorAuthor
    Jan 6, 2016 6:40 PM UTC
    David,
    Thanks for the information. I tried the offset method and it works. I never noticed that placement option in all the years that I've been using Pro/E.
    Best regards,
    Ray Aviles
