Multiple Lines of Text in a single Sketch?
Is there a way to have Multiple Lines of Text in a single Sketch?
Example:
* Improper use may cause
a hazardous condition, etc.
DKL
    mrproe1-VisitorAuthor
    Sorry what I want is to have Multiple Lines of Text in the same text entry in a single Sketch?
    Example:
    This is not possible.
    A work around is to create a symbol of the text then place it using the annotation feature.
    But this will only work on a flat Datum Plane.
    DKL
    From
    Technical Support Engineer
    Technical Support
    PTC
    Contact Technical Support
