Feb 22, 2013 5:30 PM UTC
Notes
Grouping notes with a view. Comments?
    Dale_Rosema
    Feb 22, 2013 6:57 PM UTC
    Attached is a link to a product suggestion for allowing annotations (notes) to be related to one another. My initial suggestion was for notes to a weld note, but as Antonius noted, this could between separate annotations also.
    I am not sure if this is what you meant by grouping notes within a view or not.
    http://communities.ptc.com/ideas/2186
    Thanks, Dale
    Patriot_1776
    Feb 22, 2013 7:47 PM UTC
    Yes.
    Feb 22, 2013 8:00 PM UTC
    You can relate the note to a view... so yes, you can relate several notes to a view. But grouping the notes and relating the group to a view, no, not that I can find. But as Dale noted, we would certainly like that option.
