Notification for [File->Close Window] action
Anyone knows if a notification for [File->Close Window] exists?. I tried all the model related and window-change notification types, but none of those are triggered by a window close. Also, I don't see anything obvious in the ProNotifyType enum corresponding to this.
TIA.
    TIA,
    I can see your frustration. I have not accomplished this but I would
    FV_01
    Hello all,
    Notification could by done by using technique described in:
    file://<proloadpoint>/protoolkit/protkdoc/manual0/menus.htm#476
    for ProMenubuttonPreactionSet() and ProMenubuttonPostactionSet(). The
    manual provides an example : 'Example 11: Asking for Confirmation on
    Quit Window'
    HIH.
    Feliks.
    @Patrick,
    PRO_WINDOW_CHANGE_POST was the first thing I tried. No luck.
    @Feliks,
    Thanks for the info. Your suggestion might work. I will know as soon as I find out the button name for this.
