Apr 4, 2016 9:27 PM UTC
Offset coordinate system - program
Can you create points or delete points of a "offset coordinate system" by relation or program?
    James62Answer
    Apr 5, 2016 10:04 AM UTC
    The answer is no. Try defining and using UDF that includes relations.
    UDF can take a user input.
    2-Explorer
    Apr 5, 2016 12:01 AM UTC
    No. Relations and Program can only modify existing features. You can use Program to Suppress or Resume a feature.
    However you can't add or remove individual points from a set of points in a single feature.
    Apr 5, 2016 12:42 AM UTC
    Thank you David.
    What a pity.
    It would be very important to me is that to suppress the points individually within the tool "offset coordinate system."
    If it were possible you could create curves with various amounts of folds.
    I would vary the amount of bending by a parameter.
    2-Explorer
    Apr 5, 2016 1:31 AM UTC
    You can create patterns driven by equations. It's been a while but I think memb_v is one of the arguments that would be useful.
    James621-VisitorAnswer
