Mar 16, 2015 3:58 PM UTC
offset lines in 3.0
upgraded to 3.0 from 2.0 and now some of our offset lines have lost references. is there anyway to fix these without deleting them?
    2-Explorer
    Mar 18, 2015 6:53 PM UTC
    Could it be this issue (assuming we talk about offset lines for explode states in Creo Parametric):
    CS181735 : Creation/Modification of Offset Lines in Exploded States of assembly Instances are unexpectedly lost when retrieving the Assembly Generic in Creo Parametric 3.0
    Seems to be fixed in datecode M020
    Mar 18, 2015 7:16 PM UTC
    yes to exploded offset lines. I downloaded m030 and still have the problem. doesn't seem to be fixed anymore
    2-Explorer
    Mar 19, 2015 8:20 AM UTC
    Due to the control mechanisms we have in place, "no longer fixed" is not impossible, but less likely than this being two different issues with similar symptoms or the fix being only partial (working for the reported example, but not for your model).
    You should open a case with Technical Support, providing your model, if nobody else can help.
