Offset - Replace
Hi everyone!!! I'm blocked to do an offset replace of a set of entities and the system let me select only one face at time , without the possibility to select all the set. Someone can help me??? Tanks anyway!!! Bye!!
    You can only use offset replace one face at a time. If you want to use multiple entities for offset, you need to use surfacing methods to do the job.
    Tank you!! Regards bye
