old versions
I am using WF3. I see that pro-e saves an new version everytime I hit save. How do I open the previous versions?
    In the browser window select the directory where the files are located and select Versions in the file list and Apply to display version files. In the Open File dialog box there is a black arrow with a white plus on it, select it and select All Versions in the dropdown list to display version files.
    What version of ProE are you using? It's different from version to version.
