Opening files - all versions - WF2
Gurus,
I recall being able to choose to see "all versions" of a file
by clicking on the "white plus-black arrow" icon in the upper right
corner
of the file open dialogue box.
Did this move?
Where is this capability in WF2?
Mike Singer
    Opening files - all versions - WF2It's still there. Works for me WF 2.0 M140.
    Randy Speed
    President and CEO
    Speed Consulting, LLC
    (972) 938-0490 ph (972) 937-2319 fax
    www.speedconsulting.com
    Mike,
    If you are using Windchill or intralink you will not be able to see all
    versions. Also, be sure that the directory you are looking in is not
    being purged thru some batch file. We use one here that starts pro and
    before it does it erases the trail directory. Hope this helps.
    Chris Bennett
    Sr. CAD Tech
    Stryker Instruments
    269-323-7700 x 4012
    Chris.Bennett@stryker.com
    _____
