2-Explorer
Mar 22, 2012 8:47 PM UTC
operators in relations.
Hi gang,
Does anyone know how to convert a real number to an integer in a relation?
Something like:
"SEGMENT_QTY=(INPUT_RADIUS*2*PI)INT"
Or do I need to create a new parameter of integer type and set them equal.?
-Nate
    TomU
    Mar 22, 2012 9:31 PM UTC
    If you set one parameter equal to another, the second will change type to match the first. If you have an integer parameter and set it equal to a real parameter, the integer parameter will change type to a real. (This is how you can change parameter types after they are created without recreating them.)
    To convert a real to an integer, you will need to use either the FLOOR, CEIL, functions. If you want to choose whether to round up or down automatically, you will need to write a conditional statement to pick which one to use based on your starting value.
    Tom U.
    Mar 22, 2012 9:55 PM UTC
    Here's an example of using floor and ceil to round off a number. You ought to be able to adapt it to your needs.
    /* thickness = od - id divided by 2
    thickness=(d15-d14)/2
    /* x1= step diam before rounding
    x1=d14+thickness
    /* shift moves the decimal point the number of places you want to round to
    shift=x1*1000
    /* Interger removes the numbers to the right of the decimal
    Interger=floor(shift)
    /* rounder is just the numbers to the right of the decimal
    rounder=shift-interger
    /* the following if/else statement compares the rounder to .5
    /* if the rounder is equal to or larger than .5 it rounds up. If
    /* the rounder is smaller than .5 it rounds down.
    If rounder<.5
    rounded=floor(shift)
    else
    rounded=ceil(shift)
    endif
    /* reshift moves the decimal point back to the correct place
    reshift=rounded/1000
    /* d13 = the rounded step diam minus the step clearance
    d13=reshift-0.05
    David Haigh
    nrollins2-ExplorerAuthor
    2-Explorer
    Mar 23, 2012 2:35 AM UTC
    Thanks everyone!
    Here is the answer:
    ceil() the smallest integer not less than the real value
    floor() the largest integer not greater than the real value
    And I also got a great sample to use as a template.
    And I never had to open a browser and go to the forum! Love this exploder!
    -Nate
    Mar 23, 2012 7:25 AM UTC
    The simple solution is to use:
    floor(x+.5).
    This will round x up/down according to the basic rules.
    /Bjarne
    Mar 23, 2012 1:00 PM UTC
    A simpler method to round to an integer is this:
    Rounded_parameter = floor (parameter + 0.5)
    By adding 0.5, if the value is closer to the lower integer, floor will
    still round down, if it's closer to the upper integer, adding 0.5 will
    bump it past the upper integer so floor will essentially round up.
    Doug Schaefer
    Mar 23, 2012 1:02 PM UTC
    Should have real all my mail first, Bjarne beat me to it!
    Doug Schaefer
    Mar 23, 2012 2:51 PM UTC
    I think you're missing the point of what I was trying to do in the relation example.
    Say your math ends up with a number like this 123.15963 and you want to round off to 3 places.
    123,15963 x 1000 = 123159.63
    123159.63 + .5 = 123160.13
    Floor of 123160.13 = 123160
    123160 /1000 = 123.160
    Or you could do
    Shift=(x1*1000)+.5
    Rounded=floor(shift)/1000
    Floor(x+.5) isn't letting you choose how many places you want to round off to.
    Or perhaps I'm missing your point?
    David Haigh
    Mar 23, 2012 3:04 PM UTC
    Ah yes, excellent point. If all you want to do is round to the nearest
    integer (which I think was the original question), the simple one line
    solution works. If you need to round to a specific # of places, then
    some additional trickery is required.
    Doug Schaefer
    Mar 23, 2012 3:12 PM UTC
    "An integer is any number which can be either positive and negative but not a fractional number. It is also a whole number. Examples are -1,256, -589, -1, 0, 1, 569, 5,236. It is always a rational number."
    But the whole interchange was educational regardless of the original question ..... thanks gentlemen.
    Don
    Mar 23, 2012 3:23 PM UTC
    Try this:
    L3 = floor(1000*L) - (floor(L)*1000)
    if L3 == 0
    L4 = "000"
    else
    L4 = itos(L3)
    endif
    L2 = itos(floor(L)) + "." + L4 + " "
    SIZE = BASIC_DIA + NO_THDS + " x " + L2
    [cid:image001.jpg@01CD08DE.56D51720]
    The information contained in this electronic mail transmission is intended by Weil-McLain & for the use of the named individual or entity to which it is directed and may contain information that is confidential or privileged. If you have received this electronic mail transmission in error, please notify the sender of the error by reply email so that the sender's address records can be corrected and delete it from your system without copying or forwarding it, including any reply records.
