Optimizer Algorithm in Structure
Friends,
How do I force the GDP algorithm. The default SQP is not helping me.
Randy Speed, Principal
Speed Consulting, LLC
2871 Howard Road
Waxahachie, TX 75165
(972) 938-0490 ph (972) 937-2319 fax
www.speedconsulting.com
    Dear Randy,
    Create a mecbatch file and edit it and put '-gdp' at the end of the
    command line to force the use of the GDP algroithm. PTC, in their wisdom,
    decided to remove the option from the GUI.
    Rod Giles
    Pro/Mechanica User Group
    Hey PTC are you listening?
    Put the Option back to choose the optimization routine used. I have had the optimizer not help in training classes where if GDP was used, there would have been a clear "better" solution. In the past 2 years, I have had the same thing happen in real life work: "no improvement to initial design was found (regardless of where I start it)" while a better solution is listed in the summary file above this message! WHY DID YOU DO IT? You know that SQP will not necessarily give you a better solution - it's in your documentation.
    Please give it back to us. The decision to take away our option to choose the method was not a good one! Now I have to set up a batch program to get this "old and solid" functionality back.
    Thanks David Reid and Rod Giles for the fast response.
    2871 Howard Road
