Mar 14, 2013 11:27 AM UTC
Order in which Creo displays hole/shaft tolerances
Hi there,
Can anyone tell me whether Creo Elements/Pro can display hole and shaft tolerances as Nominal +/- tol (H7) as in item 1 below, rather than Nominal H7 (+/- tol), item 2 below??
Many thanks.
Adam
    Mar 14, 2013 12:29 PM UTC
    I think/know that is working only like 2nd example.
    Vladimir
    Vladimir
    Mar 15, 2013 6:42 AM UTC
    ... if you need it, you can create new Idea
