OUT PUT FILES
Is there a way to get pro-e to put certain file extensions into a specific folder ie err, crc, out_log etc........ or is there some other option with these? thank you
    or is there a way to turn these off from being created
    7-Bedrock
    You can delete this kind of file automatically with Spekan Purge : ftp://proe:engineer@celkunststoffen.khlim.be/stud/Spurge_2.4.exe With this software you can also purge Pro/E files to keep only latest versions. Just select the root folder ans all subfolders will be cleaned.
    purge is ok, but delete is not work,why?
