May 3, 2011 9:37 AM UTC
Parabolic curve
I need to add a parabolic curve in sketcher, can someone tell me how to do this please.
Thanks in advance.
Jeff
    May 3, 2011 12:03 PM UTC
    Not directly in sketcher, but you can create a datum curve by equation.
    You should then be able to reference that curve in another sketch and
    revolve, etc...
    Christopher F. Gosnell
    FPD Company
    124 Hidden Valley Road
    McMurray, PA 15317
    May 4, 2011 9:12 AM UTC
    Use a Conic curve in sketcher, the parameter on the curve is Rho
    You can modify rho as follows:
    parabola, use the default value of 0.5.
    ● For a hyperbola, type a value between 0.5 and 0.95.
    You can also modify the angles at the ends of the curve
    Sean
