pcf advice needed
For companies with multiple printers to choose from, what is the
preferred practice?
- multiple pcf files with plotter_command defined for each printer
- 1 pcf file that uses MS_PRINT_MGR to allow user to choose the desired
printer
If your answer was multiple pcf files, how do you manage who gets which
ones (since users will only want to see the ones that they use)? I know
it adds a click for the users to select a printer if you go the
MS_PRINT_MGR route (and I think that is the only disadvantage), but that
sure seems like the simplest way to go.
AB
    We use 1 pcf file that uses MS_PRINT_MGR to allow user to choose the
    desired printer
    Herb Spaulding
    Miller Industries
    > preferred practice?
    > desired printer
    > which ones (since users will only want to see the ones that they
    > use)? I know it adds a click for the users to select a printer if you
    > go the MS_PRINT_MGR route (and I think that is the only disadvantage),
    > but that sure seems like the simplest way to go.
    > Thanks,
    > AB
    > --- You are currently subscribed to draft. To unsubscribe send a blank
    > e-mail to -. For assistance, email
    > us at - or find other contacts at
    > www.ptcuser.org/org/contacts.html. PTC/USER and the PTC/USER logo are
    > registered trademarks of PTC/USER, Inc. Pro/ENGINEER is a registered
    > trademark of PTC. Message authors are solely responsible for the
    > content of their posts.
