PDMLink 9.1 CDs
I'm trying to make sure I have the correct CDs for 9.1 M020. What is the difference between the following CDs?
  1. Windchill PDMLink 9.1 F000
  2. Windchill 9.1 Point Release F000
  3. Windchill 9.1 Service Pack M020
Do I need to install F000 before I install/upgrade to M020? Where can I find documentation on the correct CDs?
Patrick Williams | Sr. Application Engineer | Engineering Systems | Steelcase Inc. | 616.698.4078
    Try this link.
    Patrick,
    When performing our update from 9.0 M020 to 9.1 M020, we updated first to 9.1 F000 and then applied the maintenance release to 9.1 M020. The Point Release CD gets you to F000 while the Maintenance Release CD gets 9.1 F000 to 9.1 M020. I'm not sure if you can go straight to 9.1 M020 or not. I didn't try but doing the two step process worked well for us.
