Dec 14, 2011 9:05 AM UTC
pen_line_width not working properly in creo
today got a chance to take my hand on Creo... it was not good at first site as ui is totally changed and hv to click more, plus i love my meanubar which is gone now why i love it? cause i often uses keyboard which is quite important to me to work fast. meanubar increases speed of my work. anyways i hv a problem which i dont hv before. i hv trouble to change the pen_line_width in creo. by defult it is 3 and i want it to be 0.5 but creo doesnot changes value. why is that??? i tried 1,2,3,4,5... and value change is creo donot take pen_line_width in decimals why is that?? or is there anthting else that i hv to do first?
    Dec 14, 2011 1:19 PM UTC
    ahh sry my bad my table file was not configured in creo....... actually i was too excited to see new creo..
    thanx 4 reminding me
    Regards
    -Dalbeer
    Dec 14, 2011 11:35 AM UTC
    Sir
    As per the documents
    The value of penx_line_weight should be integers ranging from 1 to 16
    where 1 represents .005 inch(.127mm) width
    If pen1_line_weight 2
    Then the line width would be 0.254mm
    It is very hard to check whether system reads values like 1.25 or 1.5 . Because the lines are too thin.
    The Creo does not accept values other than integers. But you can change the value in Config.pro in notepad.
    (My old wf-5 config setting do not show any error in creo having values other than integers)
    But If you want to specify exact line width then I would suggest you to go for Pen Table File
    Regards
    K.Mahanta
    DalbeerSinghSoh1-VisitorAuthorAnswer
    Regards
    -Dalbeer
